Jul 17th, 2024, 3:28am
ocean script (Read 2519 times)
Evgenii
ocean script
May 22nd, 2013, 7:43am
Hi! I use OCEAN Script for simulations. In process to calculation (if i use 'sweep' for many corners and parameters), information in CIW is unreadable and command window frequently 'freezes'...  How to display number or name of current simulation in other way (but in CIW preferable) . Or it possible only to write to file or as label in Waveforms window...
Thanks!    :)
PS I think is possible to do if disable plotting the curves during simulation...  :) theme must be closed, sorry Wink
« Last Edit: May 22nd, 2013, 10:50pm by Evgenii »
boe
Re: ocean script
Reply #1 - May 23rd, 2013, 2:50am
Evgenii, the CIW 'freezes' because it is busy. printf/fprintf can be used to print.
- B O E
