Hi! I use OCEAN Script for simulations. In process to calculation (if i use 'sweep' for many corners and parameters), information in CIW is unreadable and command window frequently 'freezes'... How to display number or name of current simulation in other way (but in CIW preferable) . Or it possible only to write to file or as label in Waveforms window...
Thanks! :)
PS I think is possible to do if disable plotting the curves during simulation... :) theme must be closed, sorry
