Jul 17th, 2024, 10:23pm
How to Generate a Rectangular Pulse with Different Amplitudes (Read 3909 times)
Kevin Finn
May 30th, 2013, 7:57am
Hi everyone,
I've been trying to implement the following with Verilog A; however, I couldn't make it work thus far. What I wanna do is basically generate a rectangular pulse with more than 2 different amplitudes. For example, the amplitudes I want my pulse to have are 5, 3, 1, and -1 (in voltage).
During each unit interval, which's let's say 50 ns, I want my pulse to be equal to one of the abovewritten values.
I expect to code something like the following:
@(above($abstime - unit_interval) x = 5;
@(above($abstime - 2*unit_interval) x = 3;
@(above($abstime - 3*unit_interval) x = 1;
@(above($abstime - 4*unit_interval) x = -1;
pulse <+  transition (x);
However, the second line overwrites the first line, the third line overwrites the first two lines, and so on and so forth.
Could you please help me as to how I can code such a pulse in Verilog A?
Thanks in advance!
Re: How to Generate a Rectangular Pulse with Different Amplitudes
Reply #1 - May 31st, 2013, 1:16am
Try using @timer rather than @above. Use the second argument on the timer function to implement periodicity.
Kevin Finn
Reply #2 - May 31st, 2013, 2:24am
Thanks for your response, Ken!
I actually had tried the @timer event before and couldn't make it work either.
Could you please tell me what's wrong with the following code? V(out) seems to be zero at all times when I simulate it.
@(timer(0, unit_interval)) x = 5;
@(timer(unit_interval, 2*unit_interval)) x = 3;
@(timer(2*unit_interval, 3*unit_interval)) x = 1;
@(timer(3*unit_interval, 4*unit_interval)) x = -1;
V(out) <+ transition(x, 0.0, period/100.0 );
Reply #3 - May 31st, 2013, 10:19am
You have not given enough of the model to see the problem. Please give the entire module.
Kevin Finn
Reply #4 - Jun 3rd, 2013, 2:10am
Thanks for your response, Ken! Now, it's working, although I didn't get what the problem was before. I'm learning Verilog-A from scratch, so perhaps I did something nonesense.
module vsource_test (out);
output out;
voltage out;
parameter real unit_interval = 40n;
integer x;
analog begin
	V(out) <+ transition(x, 0, unit_interval/100);
