Aug 15th, 2024, 11:41pm
How to make Cadence plot output expression in new subwindow (Read 385 times)
jqjqjq
Jun 01st, 2013, 4:29am
Dear all,
I'm using cadence with IC5141USR6 (or rather, 5.10.41_USR6.127.29).
I set 9 output expressions, and after simulation, the expressions are plotted in one window and one subwindow However, I really need them to be divided into 3 groups, each group has 3 expression, and each group correspond to one subwindow. The resulting 3 subwindow should be in one window.
I believe OCEAN script could implement my intention. But I want to use the GUI, but not script. So is there any solution? I really did not find any choice or button like "Append, Replace, New Subwindow, New Window" in the output expression setup window.
Thank you all in advance.
jq
View Profile jqjqjq   IP Logged
