Oct 1st, 2026, 8:11pm
Error during simulation (Read 2561 times)
fuzail
Jun 16th, 2013, 6:37am
I have made verilog-A model of switches and using them in the circuit to perform simulation. Here spectre gives me error like "too few terminals given (3<4)".
Here i have two types of switches one is 3 terminal switch (vin,vcontrol,vout) and other is four terminal switch (vref+,vref-,vcontrol,vout) .
Operation of 1st switch is simple if vcontrol>vth then switch closed else open. (vth is given as parameter in code)
Operation of second switch is
if vcontrol>vth vout=vref+
else vcontrol <vth vout=vref-
I made symbols of both n using in switched integrator circuit along with fully differential-opamp but giving the error as described above.
If switch2(four terminal switch) is removed spectre is not showing any error..... Any help on this would be appreciated
Thanks--
Fuzail
rfidea
Europe
Re: Error during simulation
Reply #1 - Jun 16th, 2013, 11:54am
I have a longshot... Have you the same name of the switches in the two veriloga codes? Easy done if one cell originates from a copy of the other one. I have done that mistake myself a long time ago and got the same problem.
