Oct 29th, 2026, 2:49am
Help required for understanding OP-AMP Verilog AMS code (Read 4877 times)
indra0804
India
Jul 05th, 2013, 12:46am
I have started doing some work in Verilog-AMS recently. I have used some of the codes available in the designers guide website for modelling different circuits.
I have also used the code for Ideal OP-AMP available in the site and it has worked perfectly for me. But I am having a little trouble in the understanding of the code (means how it works)...!!
I am quoting the code:::
// Ideal Opamp
// Version 1a, 1 June 04
// Ken Kundert
// Downloaded from The Designer's Guide Community (www.designers-guide.org).
// Post any questions on www.designers-guide.org/Forum.
// Taken from "The Designer's Guide to Verilog-AMS" by Kundert & Zinke.
// Chapter 5, Listing 1.
`include "disciplines.vams"
module ideal_opamp (pout, nout, pin, nin);
   output pout, nout;
   input pin, nin;
   electrical pin, nin, pout, nout;
   branch (pout,nout) out;
   branch (pin,nin) in;
   analog begin
     V(out): V(in) == 0;
I am unable to understand what the branch command does??
and also what does " V(out): V(in) == 0 "  mean??
Anyone having the answer pls help.
Thanks in advance,
Indrajit
boe
Re: Help required for understanding OP-AMP Verilog AMS code
Reply #1 - Jul 5th, 2013, 3:13am
indra0804,
see Verilog-AMS LRM (languange reference manual) http://www.designers-guide.org/VerilogAMS/vams231.pdf.
- B O E
Reply #2 - Jul 5th, 2013, 10:07am
The branch statement simply declares a branch. It creates the branch and gives it a name.
The magic is in the "V(out): V(in) == 0;". You can read this statement as: Find V(out) such that V(in) == 0. This is just a rather direct statement of the virtual short circuit principle. V(in), meaning the voltage between pin and nin, is forced to be 0, but notice that nothing is contributing to or driving the in branch, and so no current flows from pin to nin.
indra0804
India
Reply #3 - Jul 8th, 2013, 5:34am
Ok, thanks Ken and Boe, Got the idea.
