Jul 17th, 2024, 8:30pm
Modeling Gm(t) of a hard-limiter Voltage to Current converter. (Read 517 times)
Ricky Chen
Jul 05th, 2013, 12:22pm
Dear All,
I have modelled a hard-limiter V-to-I converter (Gm(t)).
I want to add a noise white current noise Source in parallel to it as I= 4*K*T*Gm(t).
Can anybody please tell how to write the code for that ?
My hard-limiter V-to-I converter (Gm(t)) code is as below:-
// VerilogA for VERILOG_A_MODEL, HARD_LIMIT_GM, veriloga
`include "constants.vams"
`include "disciplines.vams"
module HARD_LIMIT_GM(in,out);
 inout in,out;
 parameter real vtrans = 0;
 parameter real tdelay = 0 from [0:inf);
 parameter real trise = 1p from (0:inf);
 parameter real tfall = 1p from (0:inf);
 parameter real Gm=-5m;
 electrical in,out;
 real vout_val;
 analog begin
        @ (cross(V(in) - vtrans, 1))  vout_val = 1;
        @ (cross(V(in) - vtrans, -1)) vout_val = 0;
        I(out) <+ Gm * transition( vout_val, tdelay, trise, tfall);
Kind Regards,
Re: Modeling Gm(t) of a hard-limiter Voltage to Current converter.
Reply #1 - Aug 2nd, 2013, 8:51am
Wouldn't it just be
   I(out) <+ white_noise(4 * `P_K * $temperature * Gm);
