tempora123
hi all,
I would like to run a trimmed simulation of my block under adexl. So I use multiple testbenches to: - find the trimming code - run the simulation of trimmed DUT over corners
But, I would like to trim the DUT always @ Troom and then run the corner analysis. In other words, the circuit for finding the trimming code should always run at Troom over all corners. Is there any possibility to achieve this, like for example setting a property for this block with fixed temp?
Thanks for your help.
