knsf3000,
Not sure what Cadence version 6 is. If you mean Virtuoso IC615 or IC616, then just use the spectrum function in the Calculator. The input to the spectrum function is the transient waveform and the output is the standard measurements: SFDR, SNR, THD, SINAD, and ENOB. If you are using earlier version then there is another function spectremeas(?), i think. It works but requires some manual intervention, for example, clipping the transient waveform.
