Jul 17th, 2024, 10:28pm
Reading strings from a file in VerilogA (Read 7136 times)
luxmee
Aug 13th, 2013, 12:45pm
I have a text file which looks like this:
x=1,y=2,z=3 'This is a comment
x=3,y=4,z=5
x=6,y=7,z=8 'Last line
I'm trying to read the file in VerilogA(values of x,y & z) and I want to ignore the comments.
I tried using the fscanf function
file = $fopen("myfile.txt","r");
$fscanf(file,"x=%d,y=%d,z=%d%s",int1,int2,int3,str1);
But this doesn't work, it works as far the syntax goes but when I run my testbench, it gives me a fatal error saying "Format string in $fscanf doesn't match input file/string".
I also tried a combination of fgets and then sscanf but that doesn't work either.
Does anyone know how to do this?
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Reading strings from a file in VerilogA
Reply #1 - Aug 15th, 2013, 7:38am
I've been able to get $fscanf to work but it is very picky - especially strings are a nuisance. Apparently a string is any character string delimited by whitespace, so if your comments include whitespace $fscanf won't work. On the other hand, the amount of whitespace does not matter - one space in the format string can match any number of spaces/tabs in the actual file, as long as it relates to a single line.
What I've found is that $fscanf reads complete lines and then tries to match the line to the format string.
Please find below a Verilog-A module definition and a text input file that at least works with the analog simulators of a few different vendors. It is a file-driven sine-wave source. All lines in the input file have to be present and have to be in the given order.
`include "disciplines.vams"
`include "constants.vams"
module vfile (out, gnd);
  parameter string fname = "vfile.ctrl";
  inout out, gnd;
  electrical out, gnd;
  real amp, offset, freq, phase;
  integer fp, n_items;
  analog begin
    @(initial_step) begin
      fp = $fopen(fname, "r");
`ifdef __TIBURONDA__
      n_items = n_items + $fscanf(fp, "Amp = %g\n", amp);
      n_items = n_items + $fscanf(fp, "Offset = %g\n", offset);
      n_items = n_items + $fscanf(fp, "Freq = %g\n", freq);
      n_items = n_items + $fscanf(fp, "Phase = %g\n", phase);
`else
      $fscanf(fp, "Amp = %g", amp);
      if (amp) n_items = n_items + 1;
      $fscanf(fp, "Offset = %g", offset);
      if (offset) n_items = n_items + 1;
      $fscanf(fp, "Freq = %g", freq);
      if (freq) n_items = n_items + 1;
      $fscanf(fp, "Phase = %g", phase);
      if (phase) n_items = n_items + 1;
`endif
      $display("Read %d specifications", n_items);
      $display("  Amp    = %g", amp);
      $display("  Offset = %g", offset);
      $display("  Freq   = %g", freq);
      $display("  Phase  = %g", phase);
      $fclose(fp);
    end // initial_step
    V(out, gnd) <+ offset + amp * sin(`M_TWO_PI * freq * $abstime + `M_PI * phase / 180);
And the file that is read through these $fscanf call has these contents:
Amp = 0.5
Offset = 0.5
Freq = 1.2e+06
Phase = 45
Hope this helps.
Cheers,
Marq
