Aug 17th, 2024, 8:40am
problem in getting power information from the given below verilog-AMS code (Read 2944 times)
susona
Sep 11th, 2013, 3:06am
i want to ask you is how to get power analysis data for verilog AMS code. i have tried with sample code given in cadence LRM but i have n't got any power information the code is given below
‘include "disciplines.vams"
module Res(p1, n1);
inout p1, n1;
electrical p1, n1;
parameter real r=5;
analog begin
V(p1,n1) <+ r * I(p1,n1);
$pwr(V(p1,n1)*I(p1,n1));
when i simulated the above code with the statement options pwr=all it didn't give any power information i tried both dc operating point analysis and transient simulation but both given same result.
Note:code is simulating but power information is not available
boe
Re: problem in getting power information from the given below verilog-AMS code
Reply #1 - Sep 12th, 2013, 5:04am
Susona,
the results are in dcOpInfo/tranOp.
- B O E
susona
Reply #2 - Sep 13th, 2013, 4:21am
hai i have seen the information on dcopinfo/tranop but there is no power information and i came to know thewarning in my designs can you help me what does it mean
ncelab: *W,DLCILIB: Library name 'analoglib' not found, defaulting to 'analogLib'.  Please see nchelp on this
DC Analysis `dcOp'
Important parameter values:
   reltol = 1e-03
   abstol(I) = 1 pA
   abstol(V) = 1 uV
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   gmin = 1 pS
   maxrsd = 0 Ohm
   mos_method = s
   mos_vres = 50 mV
Convergence achieved in 2 iterations.
Total time required for dc analysis `dcOp' was 0 s.
boe
Reply #3 - Sep 13th, 2013, 5:47am
Susona,
The power-Info should be under dcOpInfo/tranOp at <TB name>.<hierarchical path>._cds_internal_Res_.
Re the warning use nchelp as recommended:
nchelp ncelab DLCILIB
- B O E
