aherohu
Hello, Everyone, I have a problem with stb analysis that occurs frequently in opamp circuits: Loop Gain Phase rises from 0 degree (DC), while it is expected to decrease from 180 degree.
By doing a corner simulation, I get phase simulation result as shown in the attached graph. About half of the corners have phase starting from 0 at DC and rises to 90degree (normally it should start with , while the other half shows expected phase result. However, the phase at higher frequencies seems to be correct again, so temporarily no problem with getting the correct phase margin. I use expression --phase(getData("loopGain" ?result "stb"))-- to calculate phase.
I checked transient step response result of those specific corners, it shows stable and nice settling behavior, so the circuit is stable. Therefore, this problem has been ignored for a long time. However, I still want to know what caused this abnormal simulation result, and what possible solution there is? I once solved it with changing reltol, iabstol to a smaller value, but didn't succeed anymore.
Does anyone have similar experience? Could anyone give a hint what else I can try.
Thanks in advance.
