Fabian H.
I use the software "IC-CAP" from "Agilent", hereby I access to a VerilogA-model of my MOS-transistor. The external voltage and the flowing current is stored by IC-CAP. In addition, I save myself the calculated values at each call of my model, in a separate file.
The calculation of; cMOS-inverter, nMOS-inverter, CMOS ring oscillator; works well.
But I expect an iterative calculation of the currents and voltages. However, I can't find iterative calculation. At each call of my model, a true current and voltage value is calculated.
How can I make the iterations visible?
Thank you very much
