aaron_do
to be honest, you are asking questions about design using discrete transistors whereas this forum specializes in integrated designs (millions of transistors, resistors, capacitors, etc on one chip). So I doubt you will find too many experts in your field here.
That said, if you already have the transistors, you can make a board with 50-ohm traces at the inputs and outputs to the device, and use bias-tees to power the device, and measure s-parameters using a vector network analyzer. The VNAs from agilent can directly output touchstone format s2p files which you can then use in your simulation. However, you will probably need to de-embed or calibrate away the traces used in your setup. So you will have to read into this.
Bear in mind that a PA is a non-linear circuit, so ultimately, you may need to do a load-pull measurement to get the best performance out of your device.
Another thing to keep in mind is that it might be difficult to get good measurement accuracy for such a high power setup. For instance, if you simply drive the device with a small signal and measure S-parameters, you may be bypassing any self-heating effects which could affect the performance. Likewise, if you attempt a high-power measurement, you will need high-power attenuators, and some kind of linear PA to drive the device (which will also need to be de-embedded).
There are probably ways people normally do these designs at such high power, but as I said, this is not the forum where you are likely to find such expertise.
regards, Aaron
