Jul 17th, 2024, 10:22pm
a simple inverter verilogA module in Hspice simulation (Read 789 times)
xiaota
Oct 27th, 2013, 7:24pm
module V_not(in,out);
input  in;
output out;
electrical in,out;
parameter real vout_high = 5,
               vout_low = 0 from (-inf:vout_high),
               vth = 1.4,
               tdelay = 5n from [0:inf),
               trise = 1n from [0:inf),
               tfall = 1n from [0:inf);
analog
  begin
    @(cross(V(in) - vth, +1));
      V(out) <+ transition(vout_high,tdelay,trise,tfall);
    @(cross(V(in) - vth, -1));
      V(out) <+ transition(vout_low,tdelay,trise,tfall);
any question with the above inv module
when I use it in Hspice ,I can not get the right result
.hdl '.\not.va'
Xinv A Y V_not
*Vin A 0 pat(5 0 0 100n 100n 100m b1010 rb=0 r=-1)
Vin A 0 pwl(0 0 250m 5 500m 0)
.tran 1m 500m
.end
Re: a simple inverter verilogA module in Hspice simulation
Reply #1 - Nov 5th, 2013, 8:25am
The simulator should not allow you to put a contribution V(out) <+ inside a cross event.  And actually, now that I look at your code, you aren't; what you really have is
So, the cross events only control the timesteps, and the contributions are always made, and I expect you end up with
   V(out) <+ vout_high + vout_low;
You need a variable:
real vout;
analog begin
    @(initial_step)
        vout = 0;
        vout = vout_high;
        vout = vout_low;
    V(out) <+ transition(vout,tdelay,trise,tfall);
