Oct 3rd, 2026, 7:24pm
Does PSS&PSTB in Cadence ADEXL support Monte Carlo simulation? (Read 5495 times)
zwtang
Shanghai, P.R.China
Nov 09th, 2013, 3:05am
PSS & PSTB analysis can plot waveform and value, but in Monte Carlo simulation it does not work.
Anybody has the same problem. I wonder whether Cadence ADEXL supports PSS&PSTB analysis in Monte Carlo simulation.
zwtang
2013/11/9
Re: Does PSS&PSTB in Cadence ADEXL support Monte Carlo simulation?
Reply #1 - Nov 9th, 2013, 4:40am
Zwtang,
   More information would be useful. Is the issue that Monte Carlo
analysis failing? Or are you unable to plot the simulation results?
Are you calculating gain margin and phase margin from the
mag/phase plots or using the stability analysis results?
zwtang
Shanghai, P.R.China
Reply #2 - Nov 10th, 2013, 5:36am
Sheldon,
Thanks!
Normal and Corner simulations can plot waveforms and evaluate expressions, but Monte Carlo simulation can not.
For example,
LoopGain_dB_dm = value(value(value(db(mag(getData("loopGain" ?result "pstb"))) "harmonic" 0.0) "freq" 10) "cmdm" 1)
cmdm is a variable used in "cmdmprobe" cell. "freq" 10, i want get voltage gain at 10Hz.
zwtang
2013/11/10
Reply #3 - Dec 27th, 2013, 4:40am
Which version of the simulator (and Virtuoso) are you using? I was running with IC616 ISR4 and MMSIM13.1 ISR2 and it works OK for me. I have this as my expression:
value(value(db(mag(getData("loopGain" ?result "pstb"))) "harmonic" 0) "freq" 10)
and that works fine. Note that the db(mag()) is a bit redundant - you can just use db() instead of db(mag()) - it already does the mag inside the db function. Also, I had a variable cmdm but you shouldn't need to find the value of the expression at that - if you're sweeping it in a corner, ADE XL will evaluate it at each corner anyway.
Kind Regards,
