Aug 16th, 2024, 2:57pm
array of nodes (Read 2571 times)
aaron_do
array of nodes
Jan 13th, 2014, 11:08pm
I want to create a circuit model with a large number of ports (say 1000). In the Verilog-A manual, it says I can create Vectored Nodes, but I can't get this feature to work. The error I get is:
line 7: Encountered a vector node with a scalar member in a port list, which the software does not support
so are vectored nodes supported or not?
thanks,
Aaron
Re: array of nodes
Reply #1 - Jan 14th, 2014, 6:26am
Can you please show what you've actually tried? Also which simulator you're using?
aaron_do
Re: array of nodes
Reply #2 - Jan 14th, 2014, 7:19pm
OK sorry, but it seems it was a false alarm.
this is what I originally tried
Quote:
module whatever(out[0], out[3]);
output [3:0] out;
electrical [3:0] out;
which I got from this document called "SIMetrix Verilog-A Manual" pg 31. I also tried
module whatever(out[3:0]);
but I got a similar error message. Anyway after you asked for my code I assumed that it is possible to declare a large number of ports, and I found the correct method in the Verilog-A Language Reference Manual Version 1.0., pg 114. I thought I tried this yesterday too but I guess I didn't...
Quote:
module whatever(out);
output [3:0] out;
thanks,
Aaron
