If you're running with corners in ADE XL, then each simulation will be a separate run of the simulator - and hence a different process. So I doubt it's overwriting the results that's the problem here. Note that if you use ~/results/%P.txt or whatever, and then are using distributed processing (e.g. LSF) there's a chance that the process ids might clash, as you could end up with the same process id on different machines (you could even on the same machine if there are a lot of runs and the machine is busy, as it could cycle around the process ids, but that's pretty unlikely). But as I said, I doubt that's your real problem. Maybe you should contact Cadence's customer support at http://support.cadence.com ? Regards, Andrew.
