Aug 15th, 2024, 4:52pm
How can I sweep actimes in trans analysis? (Read 3216 times)
aaron_do
Feb 11th, 2014, 12:57am
I'm using Spectre Trans analysis, and I want to sweep the option actimes. Does anybody know how?
thanks,
Aaron
Re: How can I sweep actimes in trans analysis?
Reply #1 - Feb 16th, 2014, 12:38am
Well, you can add a sweep around the analyses which is varying the actimes - as follows:
parameters act=0.5u
V1 (in 0) vsource type=sine mag=1 freq=1M ampl=1.2
R1 (in out) resistor r=1k
C1 (out 0) capacitor c=1p
sweepact sweep param=act start=0.1u stop=0.8u step=0.1u {
    ac ac start=1 stop=1G
    tran tran stop=1u acnames=[ac] actimes=[act]
Of course this is a completely silly example...
I suspect this is not what you're asking (it wasn't very precise). Are you asking to do a single transient where the actimes is a sweep rather than a list of literal values? If so, you can't do that... you should contact http://support.cadence.com as it's a reasonable request for an enhancement.
aaron_do
Reply #2 - Feb 16th, 2014, 6:06pm
Hi Andrew,
thanks for the reply. Yeah I see that in your example I would need to run N times as many analyses. Right now I need to type in each actime that I want included. See if I get around to contacting support...
thanks,
Aaron
boe
Reply #3 - Feb 18th, 2014, 10:50am
Hi Aaron,
I recently asked the support for that. The answer I got:
"as for tran and actimes there is yet no such advanced “acperiod” option, you could also do a for loop and run a tran for each code."
- B O E
