Jul 21st, 2024, 12:27pm
transient simulation  with s-parameter file (Read 3576 times)
sammy_bee
Mar 13th, 2014, 3:57pm
What possibly could go wrong with  during a transient simulation with an S-parameter in spectre ? I was just trying to measure the resistance of a bondwire.  I  have modeled the  bondwire as an S parameter file.  I had a  voltage step at the  input with a current source at the  output of the nport  instance. The resistance value seems too high.
Re: transient simulation  with s-parameter file
Reply #1 - Mar 13th, 2014, 10:06pm
It appears that you are trying to measure a dc, low frequency,
quantity. What was the minimum frequency you defined in your
s-parameter file? Did you define a dc value? If the minimum
frequency is 100MHz and you are trying to get a dc value then
did you do anything to improve the dc value estimation, for
example, set dcextrap? More/any detail about what you are doing
would be helpful.
sammy_bee
Reply #2 - Mar 14th, 2014, 8:06am
I had the DC extrapolation set to unwrap and the minimum frequency is 10Hz
Reply #3 - Mar 16th, 2014, 1:08am
Which version of the simulator are you using? What options have you set on the nport (ideally show the line in the input.scs so we can see all the options).
Kind Regards,
