I have also seen this kind of behaviour caused by poor Verilog A models. For example, I have seen a few cases where people model non-linear resistance with a quadratic (or higher order) equation, neglecting the fact that quadratic equations have multiple roots. If those roots represent completely non-physical behaviour, the simulator doesn't know that - so it may be a "correct" solution to have large negative voltages if the model is not reasonable...
