Jul 21st, 2024, 4:27am
How to set maximum and minimum allowed voltage for hspice convergence? (Read 2113 times)
neoflash
Mixed-Signal
Designer
Mar 20th, 2014, 11:32am
One of my simulation tends to converge to several thousands volts or negative voltage before totally give up.
If there is a knob to set the max and min allowed value during initial condition convergence, that may help simulator to converge.
Is there such knob available in hspice?
Re: How to set maximum and minimum allowed voltage for hspice convergence?
Reply #1 - Mar 24th, 2014, 12:31pm
I have a vague recollection of a way to set a maximum per-iteration change of voltages.  However, I don't think this is necessarily a good idea.  The linear solver can end up with some crazy values when trying to use Newton's method to solve a nonlinear circuit.  Generally, the simulator vendors have some sophisticated methods of improving convergence, and any attempts to tinker with the voltages might end up working against the internal tricks.
Reply #2 - Apr 7th, 2014, 10:56am
I have also seen this kind of behaviour caused by poor Verilog A models. For example, I have seen a few cases where people model non-linear resistance with a quadratic (or higher order) equation, neglecting the fact that quadratic equations have multiple roots. If those roots represent completely non-physical behaviour, the simulator doesn't know that - so it may be a "correct" solution to have large negative voltages if the model is not reasonable...
