Sep 21st, 2026, 6:08pm
Receiver test setup and calibration (Read 12488 times)
mixed_signal
Apr 09th, 2014, 7:28am
I want to plan test setup of my receiver. My receiver needs RF+ , RF- , LO+, LO- which I am generating using offchip baluns and introducing inside chip using RF probes as in Fig. 1.
1. I want to calibrate balun/probe loss because I want to subtract it from my total RX noise figure. I have a plan as shown in Fig. 2 where I want to measure the S21, find half the loss and remove it from total NF. The pads are identical, close and shorted. Is that OK? Has anyone better suggestion?
2. I have a baseband buffer @ 30MHz . The input is obviously not matched to 50 ohm. Is it necessary to match the output to 50 ohm @ 30 MHz since it will drive 50 ohm instruments.
3. I want to calibrate the NF and gain of the buffer and hence I have a lonely version. Is it required to matched I/P and O/P at 30 MHz now?
aaron_do
Re: Receiver test setup and calibration
Reply #1 - Apr 9th, 2014, 9:53pm
1) I think that method is quite OK. I think it is accurate as long as your design is more or less matched to 50-ohm. Outside of your design's bandwidth, I suspect the answer won't be right since there will be reflection.
http://www.designers-guide.org/Forum/YaBB.pl?num=1233236788/1#1
2) This answer is just an IMO...I think it needs to be able to drive 50-ohm, but doesn't need to be matched to 50-ohm. In the first place, one wavelength at 30 MHz is 10m (free space). Also, I think you would only have problems if your load is unmatched, but in your case, its the analyzer (50-ohm). So for example if your load was not 50-ohm, then there would be reflection at the load, and when the reflected wave reached your "unmatched" device, it would be re-reflected. I think the concern is that if there is too much bouncing around, the resulting distortion can cause ISI.
3) For the output, just do whatever you did in the full version. For the input, if your input impedance is high, then you will get an automatic 6dB gain (it will be slightly less). However, if you add a 50-ohm matching resistor, then it will affect your NF. If it were me, I would not add any matching. Just make sure you interpret the s-parameter data properly when you want to de-embed the gain.
A lot of IMOs in my answers. Maybe somebody can give their opinion.
hope it helps,
Aaron
mixed_signal
Reply #2 - Apr 10th, 2014, 8:44am
Hi aaron_do,
Thank you very much! Highly appreciate your feedback.
mixed_signal
Reply #3 - Apr 10th, 2014, 2:24pm
Hi aaron_do,
Part 3) Can I measure noise figure if input of the buffer is not matched to 50 ohm. I plan to use Y factor method using spectrum analyzer.
aaron_do
Reply #4 - Apr 10th, 2014, 5:14pm
unfortunately its been a while since I've done NF measurements. I don't see any reason why you need to match the input. A side note, I seem to recall situations where my device noise was very close to the instrument's noise floor and this resulted in inaccurate results. Perhaps you should consider this...
regards,
Aaron
EDIT: I've just looked at some documents, and it seems that mismatch may be important for Y-factor NF measurement. The document is called "Noise Figure Measurement Accuracy - The Y-Factor Method - Application Note" and it can be found here:
http://www.home.agilent.com/en/pd-331902-pn-E4402B/esa-e-series-option-219-noise...
If you want to double-check, you could do some noise simulations and try to calculate noise figure using the Y-factor method. See if there's any difference in the result when the device is matched or not...
« Last Edit: Apr 10th, 2014, 6:19pm by aaron_do »
mixed_signal
Reply #5 - Apr 11th, 2014, 8:10am
Thank you very much aaron_do!
LazyDesigner
South Korea
Reply #6 - Oct 30th, 2014, 6:47pm
HI Aaro_do,
Whats your opinion on output impedance matching as asked in #2, if signal BW changed from 30MHz to 1GHz,  do we only need to drive 50ohm or we should match it to 50ohm?
View Profile sainiparvesh   IP Logged
