alirezad
I am simulating a mixed signal design in virtuoso 6.1.6 with two simulators as follows: 1. Spectre APS simulation of transistor level design 2. AMS simulation using verilog models of digital blocks
I am seeing that - quite surprisingly - #1 runs faster than #2. In order to see where the AMS simulator is spending time, I look at the profiler. On the stream count section, the top %hits that I see go to the following streams: ssslib snare support outside engine Method SSS_MT_MINNOW (method)
Also the stream type section is topped by "support for VPI callbacks (or UI)."
I couldn't find much information on what these mean and what I can do to speed up my sims. I appreciate if anybody can shed some light or point out some references.
