Jul 16th, 2024, 7:21pm
pss gives wrong time domain waveform (Read 4663 times)
Jul 28th, 2014, 4:58am
Hi Guys,
PSS gives wrong time domain waveform when I run pstb for a buck model. Transient analysis shows the model works. The following is the test bench of the buck model. What's wrong with my simulation?  I think the default engine for pss analysis is newton-shooting, too.
Yawei
Re: pss gives wrong time domain waveform
Reply #1 - Jul 28th, 2014, 5:09am
The following is simulation result, where the red line is transient analysis result and the blue line is the pss-tran result.
raja.cedt
Reply #2 - Jul 28th, 2014, 6:17am
hi ywguo,
Would be nice if you can show schematic one level below. Did you check PSS log file??
Raj.
Reply #3 - Jul 28th, 2014, 10:39pm
Hi Raja,
The following is the schematic of buck, which is DUT in the previous test bench. Thank you.
Yawei
Reply #4 - Jul 30th, 2014, 5:41pm
I got the answer. The pss analysis is not in the argument list of initial_step in the opamp model.
analog begin
@(initial_step ("dc","ac","tran","noise","stb"))
  begin
  Vhi=V(vdd);
  Vlo=V(gnd);
  v_th=(Vhi-Vlo)/2;
Yawei
