abhinav
I was configuring the new PDK in Cadence virtuoso version IC6.1.4.500.12( one PDK is already existing in the home directory). so i make a new folder(named "new_PDK") in the home directory and added the files(cadence.cshrc, cds.lib, .cdsinit, .cdsenv, bindkeys and the PDK folder). when i source the cadence.cshrc file from from folder new_PDK, i am listing out the problems i am facing:
1. its shows techfile conflict
" there is a conflict in techfile graph
Look at techfile reported error massage in CIW
correct techfile conflict before proceeding "
Whill loading the files, it takes techfile.tf, pdkutil and display.drf file from PDK folder olny.
2. In the schematic window, i can call the instances but unable to connect using wires(wires are not coming. rest all shortcut keys are working.
" p, li { white-space: pre-wrap; } |||||||color set to unbound, was nil
|||color set to nil, was nil
* Field is "color" *
*Error* hiCreateCyclicField: value must be contained within the list of choices
3. In the layer selection windows(LSW) palletes are not visible.
" (LE-101804): Cannot get valid layer form LSW window. "
i can see the layer when i click on layer but again shows blank when i scroll it down.
4. Cadence windows crash when i try to make any layer in the layout.
" \o (LE-101804): Cannot get valid layer form LSW window. \a leSetLSWBBox(list(57:328 207:1028)) "
Everthing working properly with the old PDK exist in home directory.
Please help me out.
