petitidiot
I have run a transient simulation on a chopping instrumentation amplifier. With the default settings, and accuracy defaults set as conservative, everything is ok: input is a sine wave and output is an amplified sine wave. However, when I tuned gmin from 1e-12 to 1e-24, the transient output showed oscillation with the chopping frequency. The output.log said it tried "homotopu = gmin" "homotopy = source" "homptopy = dptran" to get the initial conditions. Then which settings I should trust? A smaller gmin is always more accurate and reflects the real situation? Attached is part of the output.log file. Please help!Thanks!
Circuit inventory: nodes 146 bsim3v3 217 bsource_1 14 capacitor 16 isource 3 vsource 30
Notice from spectre. 77 warnings suppressed.
Time for parsing: CPU = 6.999 ms, elapsed = 9.06682 ms. Time accumulated: CPU = 313.952 ms, elapsed = 308.797 ms. Peak resident memory used = 32.3 Mbytes.
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre32_8384_94, ).
Warning from spectre. WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
************************************************ Transient Analysis `tran': time = (0 s -> 20 ms) ************************************************ Trying `homotopy = gmin' for initial conditions. Trying `homotopy = source' for initial conditions. Trying `homotopy = dptran' for initial conditions.. Important parameter values: start = 0 s outputstart = 0 s stop = 20 ms step = 20 us maxstep = 200 us ic = all useprevic = no skipdc = no reltol = 100e-06 abstol(V) = 1 uV abstol(I) = 1 pA temp = 27 C tnom = 27 C tempeffects = all errpreset = conservative method = gear2only lteratio = 10 relref = alllocal cmin = 0 F gmin = 1e-24 S
tran: time = 500 us (2.5 %), step = 130.6 ns (653 u%) tran: time = 1.5 ms (7.5 %), step = 91.65 ns (458 u%) tran: time = 2.5 ms (12.5 %), step = 99.63 ns (498 u%) tran: time = 3.5 ms (17.5 %), step = 166.7 ns (833 u%) tran: time = 4.5 ms (22.5 %), step = 115.6 ns (578 u%) tran: time = 5.5 ms (27.5 %), step = 85.65 ns (428 u%) tran: time = 6.5 ms (32.5 %), step = 948.9 ps (4.74 u%) tran: time = 7.5 ms (37.5 %), step = 66.76 ns (334 u%) tran: time = 8.5 ms (42.5 %), step = 103.9 ns (519 u%) tran: time = 9.5 ms (47.5 %), step = 133.4 ns (667 u%) tran: time = 10.5 ms (52.5 %), step = 106.5 ns (533 u%) tran: time = 11.5 ms (57.5 %), step = 66.69 ns (333 u%) tran: time = 12.5 ms (62.5 %), step = 111 ns (555 u%) tran: time = 13.5 ms (67.5 %), step = 1.243 ns (6.21 u%) tran: time = 14.5 ms (72.5 %), step = 172.4 ns (862 u%) tran: time = 15.5 ms (77.5 %), step = 120.3 ns (602 u%) tran: time = 16.5 ms (82.5 %), step = 1.017 ns (5.08 u%) tran: time = 17.5 ms (87.5 %), step = 1.124 ns (5.62 u%) tran: time = 18.5 ms (92.5 %), step = 139.2 ns (696 u%) tran: time = 19.5 ms (97.5 %), step = 132.1 ns (660 u%) Number of accepted tran steps = 72140 Initial condition solution time: CPU = 1.36779 s, elapsed = 1.36807 s. Intrinsic tran analysis time: CPU = 112.155 s, elapsed = 112.182 s. Total time required for tran analysis `tran': CPU = 113.529 s (1m 53.5s), elapsed = 113.561 s (1m 53.6s). Time accumulated: CPU = 115.155 s (1m 55.2s), elapsed = 117.525 s (1m 57.5s). Peak resident memory used = 249 Mbytes.
finalTimeOP: writing operating point information to rawfile.
****************** DC Analysis `dcOp' ****************** Important parameter values: reltol = 1e-03 abstol(V) = 1 uV abstol(I) = 1 pA temp = 27 C tnom = 27 C tempeffects = all gmindc = 1e-24 S Trying `homotopy = gmin'. Convergence achieved in 65 iterations. Total time required for dc analysis `dcOp': CPU = 73.989 ms, elapsed = 78.5849 ms. Time accumulated: CPU = 115.254 s (1m 55.3s), elapsed = 117.635 s (1m 57.6s). Peak resident memory used = 249 Mbytes.
dcOpInfo: writing operating point information to rawfile. modelParameter: writing model parameter values to rawfile. element: writing instance parameter values to rawfile. outputParameter: writing output parameter values to rawfile. designParamVals: writing netlist parameters to rawfile. primitives: writing primitives to rawfile. subckts: writing subcircuits to rawfile.
