Fabian H.
does any body know where to find, or can any body give me a small working example of the two not working examples given in Verilog-AMS Language Reference Manual Version 2.4.0 May 30, 2014 described in Section 12.22.2 Examples and/or 12.32.3 Examples.
I only know these two examples, which starts VPI-routines within a analog section. Do you know other examples?
I tried to compile these examples in a small circuit, but the compilation gained different errors. Of course I added the header files vpi_user vpi_cds_user andvpi_ams.
I invoked the compilation for the sample and hole example with: irun scf.scs top.vams sampler.vams sampler.c -loadvpi:sampler_compile_tf
I received the following errors:
Can you pleas help me?
Thanks a lot
regards Fabian
ncsc: compiling $TESTDIR/sampler.c
make: *** [INCA_libs/irun.lnx8664.13.10.nc/ncsc_run/ncsc_obj/sampler.o] Error 1 $TESTDIR/sampler.c: In function 'sampler_compiletf': $TESTDIR/sampler.c:68: error: request for member 'type' in something not a structure or union $TESTDIR/sampler.c:70: error: request for member 'real' in something not a structure or union $TESTDIR/sampler.c:32: warning: unused variable 'value' $TESTDIR/sampler.c:29: warning: unused variable 'cb_data' $TESTDIR/sampler.c:28: warning: unused variable 'returnHandle' $TESTDIR/sampler.c: In function 'sampler_calltf': $TESTDIR/sampler.c:80: warning: cast to pointer from integer of different size $TESTDIR/sampler.c:85: warning: implicit declaration of function 'vpi_set_value' $TESTDIR/sampler.c:81: warning: unused variable 'value' $TESTDIR/sampler.c: In function 'sampler_postcompile_cb': $TESTDIR/sampler.c:97: warning: implicit declaration of function 'malloc' $TESTDIR/sampler.c:97: warning: incompatible implicit declaration of built-in function 'malloc' $TESTDIR/sampler.c:107: error: 'periodHandle' undeclared (first use in this function) $TESTDIR/sampler.c:107: error: (Each undeclared identifier is reported only once $TESTDIR/sampler.c:107: error: for each function it appears in.) $TESTDIR/sampler.c:111: error: 'acbElapsedTime' undeclared (first use in this function) $TESTDIR/sampler.c:113: error: request for member 'type' in something not a structure or union $TESTDIR/sampler.c:113: error: 'vpiScaledTme' undeclared (first use in this function) $TESTDIR/sampler.c:115: error: request for member 'real' in something not a structure or union $TESTDIR/sampler.c: In function 'sampler_update_cb': $TESTDIR/sampler.c:131: error: 'acbAbsTime' undeclared (first use in this function) $TESTDIR/sampler.c:133: error: request for member 'type' in something not a structure or union $TESTDIR/sampler.c:133: error: 'vpiScaledTime' undeclared (first use in this function) $TESTDIR/sampler.c:135: error: request for member 'real' in something not a structure or union $TESTDIR/sampler.c:135: warning: implicit declaration of function 'vpi_get_analog_time' $TESTDIR/sampler.c:136: warning: implicit declaration of function 'register_callback' $TESTDIR/sampler.c: At top level: $TESTDIR/sampler.c:148: warning: initialization from incompatible pointer type $TESTDIR/sampler.c:149: warning: initialization from incompatible pointer type $TESTDIR/sampler.c:153: warning: excess elements in struct initializer $TESTDIR/sampler.c:153: warning: (near initialization for 'sampler_systf') ncsc_run: *E,TBBLDF: Failed to generate object ./INCA_libs/irun.lnx8664.13.10.nc/ncsc_run/ncsc_obj/sampler.o
