I am trying to run 'virutoso -nograph' and I get the following errors:
Code:Trying another display...
*WARNING* Could not open display hostname:89. If no X server is running for this display,
*WARNING* remove the file /tmp/.X11-unix/X89: owner user, last modified Mon Nov 3 10:14:00 2014
*WARNING* Giving up after trying 10 displays.
*WARNING* Unable to connect to a non-graphical X Window Display server.
*WARNING* Try using the -vncTenbase option or the CDS_XVNC_TENBASE environment variable to specify a different set of 10 displays.
The irony of this is that I can start virtuoso fine when I don't ask for -nograph mode (when I ask it not to use the X server, it fails saying it cannot find the xserver, otherwise it works without problems).
I have tried searching with Google: no luck finding anything on this error message from Cadence or on non-graphical X servers in general.
Does anyone have any suggestions on how to get virtuoso talking to the 'non-graphical X Window Display server', whatever that is?
August
