Aug 20th, 2024, 11:18pm
Pages: 1 2
stb phase margin (Read 19037 times)
boe
Re: stb phase margin
Reply #15 - Dec 18th, 2014, 7:37am
newic wrote on Dec 17th, 2014, 7:09pm:
Hi buddypoor
"(I think, STB analysis requires that both loops are to be opened at the same time) "
how to achieve that in STB if having 2 loops?
In the STB setup, only one probe is allowed.
See Frank's answer in this thread.
- B O E
buddypoor
Bremen, Germany
Reply #16 - Dec 18th, 2014, 9:39am
boe wrote on Dec 18th, 2014, 7:37am:
Hi buddypoor
- B O E
Yes - I know this answer. But it does nort help at all because Frank just confirms that BOTH loops have to be opened at the same time.
But - if this not always possible (i.e. nested loops).
anhnha
Earth
Reply #17 - Aug 4th, 2016, 7:58pm
When you have several loops you should find a common point where you can break all the loop. For example band gap, opamp o/p is prefect point to keep stb-probe.
Could you tell me where to put the iprobe for this bandgap?
http://kitmonisit.com/
Pages: 1 2
