Jul 18th, 2024, 12:38am
Paramset selection based on temperature (Read 3235 times)
ee2
Jan 13th, 2015, 11:55am
I have a Verilog-A model that uses different paramsets based on the instance parameters (i.e. paramset overloading as described in 6.4.2 of the Verilog-AMS LRM).
Is it possible to do select the paramset based on the simulator temperature ($temperature) rather than an instance parameter?
Or is there a better way in Verilog-A to select parameter values based on simulator temperature?
Thanks.
Re: Paramset selection based on temperature
Reply #1 - Jan 16th, 2015, 12:09pm
I haven't seen an example using $temperature, but I don't see any reason that that wouldn't be allowed.  The original paramset proposal had the idea that one might pick a model based on a design switch -- eg, if you are doing digital or analog simulation of the block.
Usually, though, the model has its own temperature-update equations, and one specifies parameter values for the nominal temperature (tnom or tref).  Sometimes, there will be subcircuit equations involving temperature.  I wouldn't expect to need a paramset -- unless you're trying to pick one model for room-temperature operation, and a completely different model for super-cold (superconducting?) or super-hot (industrial) temperatures.
ee2
Reply #2 - Jan 16th, 2015, 2:19pm
Thanks Geoffrey. As you guessed, I’m doing this for modeling at extreme temperatures.
I was hung up on trying to get the $temperature set as an instance parameter so that it could be used in the selection of the paramset.
After reading your post I revisited the paramset selection criteria and realized I could use a localparam set to $temperature within the paramset and that will be used in the paramset selection. This method is working for me now.
Reply #3 - Jan 20th, 2015, 1:30pm
Glad to hear it's working.
