Jul 18th, 2024, 12:38am
Verilog-A: 2-port passive device. Z=1/(As)^3 (Read 3536 times)
CMOS-Tangram
Feb 01st, 2015, 1:42pm
Dear all,
I started learning Verilog-A some months ago for a specific objective. I have programmed the 90% of a system formed by different devices, but there’s a punctual device that I can’t solve.
I want to program a 2-port passive device. For example, if the impedance of an inductor is Ls, and of a capacitor 1/Cs, the impedance of this dispositive should be as follows: Z = 1/(As)^3. Where A is a constant like C or L.
I have tried several verilog-A codes, but no one has worked. I suppose that this is related to my inexperience in the verilog-A programming. I will appreciate any tip or solution for this problem.
Thanks in advance.
Re: Verilog-A: 2-port passive device. Z=1/(As)^3
Reply #1 - Feb 2nd, 2015, 12:18pm
I don't know what a punctual device is, or what dispositive means, but I do know that you cannot combine inductors and capacitors and get an impedance of Z = 1/(As)3.
CMOS-Tangram
Reply #2 - Feb 3rd, 2015, 6:51am
I want to program in verilog-a this device since is not possible to obtain that impedance by combination of capacitors and inductors. The temporal response of this device should be as follows:
V=1/A · (∫Idt)3
or
I=d/dt (V*A)1/3
I have tried this code:
module nonlin(p,n);
inout p,n;
electrical p,n;
parameter real A=1;
analog
I(p,n)<+ddt(pow((V(p,n)*A),(1/3)));
The programmed device is not working properly. Is there another way to program it?
*I'm Sorry Ken. The term "punctual" has been a translation error. (English is not my first language)
Reply #3 - Feb 3rd, 2015, 12:37pm
In your first message you said you wanted an impedance that was proportional to 1/s3. In your second, you said you wanted a voltage that was proportional to q3 (the integral of i is q). Those are two completely different things.The first is linear with third order dynamics, the second is nonlinear with first order dynamics.
In your first message you indicated you wanted a two port, but then you only specified its impedance.
Perhaps you should take some time and develop a clear understanding of what you need. It will be much easier to help you if you can convey a clear and consistent request.
