Jul 16th, 2024, 3:35pm
How to generate a clock signal with random noise in Cadence Spectre? (Read 1456 times)
BackerShu
Apr 10th, 2015, 10:08pm
I am trying to generate a clock signal with random noise, but not using complicated VCO models in Cadence Spectre.
One possible way I think is to use the vsource in analogLib with "prbs" type, and specify the bit file with "...0101..." pattern. So that, I can put the noise for the pattern as provided by the vsource model.
But I don't know how to construct the bit file. Could someone please explain how to do it or direct me to some reference?
