Dec 12th, 2025, 9:18am
Stability Analysis using MDL (MMSIM 12.1) (Read 3939 times)
R Raja
Apr 15th, 2015, 2:37am
The Cadence spectremdl supports stability analysis from MMSIM 12.1 version. But the mdl documentation in MMSIM 12.1 is silent on the expressions to be used to extract parameters such as Phase margin and gain margin from the "raw" results directory which is created by the MDL run.
Does any body here know what is the expression which can make MDL return the value of Phase margin after a stability analysis ?
Thanks in advance,
R Raja
