Oct 4th, 2026, 3:19pm
Negative NF for LNA in Hspice simulation and 0dB of input and output matching (Read 4301 times)
nguks
May 11th, 2015, 8:35am
Currently I am trying to simulate the noise figure, S11 and S22 parameters for LNA at 2.4GHz in HSPICE. Below is the code I used:
Calculate noise figure:
.ac dec 50 400MEG 3g
.NOISE v(vout) vin 1
Calculate S11 and S22:
.net v(vout) vin rin=50 rout=50
.print s11(db) s11(m) s11(p)
.print s22(db) s22(m) s22(p)
However, I get negative NF after calculate from the following:
**** resistor squared noise voltages (sq v/hz)
element 0:r3
rs 9.1186f
1/f 0.
total 9.1186f
rx 5.2622k
**** total output noise voltage = 433.9253f sq v/hz
NF = 10log(9.1186f/433.9253f) = -16.77dB
and get 0 value for S11 and S22:
freq s11 s11 s11
db mag phase
400.00000x 0. 1.0000 180.0000
418.85142x 0. 1.0000 180.0000
2.41024g 0. 1.0000 180.0000
freq s22 s22 s22
db mag phase
Can I know did I do wrongly? Or why these values appear?
Thank you.
Re: Negative NF for LNA in Hspice simulation and 0dB of input and output matching
Reply #1 - May 12th, 2015, 9:44am
Isn't NF the ratio of the total to the input resistor noise, rather than the other way around?
nguks
Reply #2 - May 13th, 2015, 10:59am
I think NF is 10log(SNRin/SNRout)
Reply #3 - May 15th, 2015, 10:46am
But SNR should be the ratio of signal power to noise power, not the "total output noise voltage"
If you have (S/N)_in / (S/N)_out, then you do end up with something that has N_out / N_in, which is what I was trying to say, though I agree I didn't get the formula right.
