Jul 18th, 2024, 4:31am
VerilogA model for 'dependent power source' (Read 1317 times)
a_k
Aug 03rd, 2015, 1:08pm
Hi ALL,
I have to model a two port network with `dependent power source` in VerilogA. The input port as shown in the attached figure has a simple dependent current source (where ic is a external control current). The power across the dependent current source is transferred to the output port without any loss. Thus we have an ideal dependent power source at the output port.
The two port network equations are given below:
1) i1 = ic (external current)
2) i2 = const*ic  [const is a constant]
3) v1 = const*v2
4) i1*v1 = i2*v2
The problem that I am facing is that I have to model the output port as both dependent current and voltage sources at the same time which I think is not possible in VerilogA.
Could anyone please tell me how can I model a dependent power source as described above?
Thanks in advance.
Re: VerilogA model for 'dependent power source'
Reply #1 - Aug 3rd, 2015, 5:14pm
I believe you have too many equations. Perhaps you are trying to model an ideal transformer? It has the characteristic of having the input power equal to the output power.
a_k
Reply #2 - Aug 6th, 2015, 9:16am
@Ken,
I am really sorry for the late reply.
I am trying to model a dependent power source (I am not sure if I can call this an ideal transformer as i1 is defined by an external current source which is not a part of input port).
These dependent power sources occur in boundary condition mode operation of Boost converters. I am trying to use the average large signal model for boost converter simulations.
But the problem as I mentioned earlier, is that I have to model the output port as both dependent current and voltage sources at the same time which I think is not possible in VerilogA.
Is there any method that can be used to describe this model in VerilogA?
Reply #3 - Aug 6th, 2015, 5:26pm
If you can come up with a reasonable set of equations, describing them in Verilog-A should be easy.
boe
Reply #4 - Aug 7th, 2015, 2:24am
a_k, Ken,
I believe, equations 2 and 3 should do the trick... (assuming the const is the same, which is required to satisfy equation 4)
- B O E
Reply #5 - Aug 7th, 2015, 11:35am
2) v1 = N v2
3) i1 v1 = i2 v2
Substituting (2) into (3) gives
4) i1  N v2 = i2 v2
or
5) i1  N = i2
Equations (2) and (5) together are the equations for an ideal transformer. I believe the following should work as an ideal transformer model in Verilog-A.
module ideal_transformer(pp, pn, sp, sn);
parameter real N;
electrical pp, pn, sp, sn;
analog begin
    V(sp, sn) <+ N*V(pp, pn);
    I(pp, pn) <+ N*I(sp, sn);
a_k
Reply #6 - Aug 11th, 2015, 6:11am
@BOE,
Thanks for your suggestion.
@Ken,
Thanks a lot for the code. The equations work for trans analysis.
I will have to check if they work for AC analysis as well.
