saqibshah
Please mention the units correctly - are you referring to uV or us?
Also please attach the output node waveforms - you need to make sure that opamp is actually slewing properly so as to say. A 1us input pulse might actually not be giving your opamp enough time to properly slew. Also, what is the value in volts of the input step?
Finally, what is the rise time/ fall time of the pulse?
