Aug 15th, 2024, 8:35am
Slew Rate Test for OP-AMP (Read 3336 times)
Ramakrishna RSSM
Oct 27th, 2015, 11:51am
Hey All,
I have setup my Op-Amp under Slew Rate Test....
Input 1m Pulse-------->slewRate is 45K
Input 1u Pulse-------->slewRate is 45M
I'm unable to interpret What is the SLEW RATE of my design.....?
At what value of Input Pulse Slew Rate should be measured.....?
Follow the attachments for my concern......
Thanks in advance.......
Ramakrishna RSSM
Re: Slew Rate Test for OP-AMP
Reply #1 - Oct 27th, 2015, 11:53am
Sorry,
forgot to attach u_scale file.....
saqibshah
Reply #2 - Oct 28th, 2015, 5:16am
Please mention the units correctly - are you referring to uV or us?
Also please attach the output node waveforms - you need to make sure that opamp is actually slewing properly so as to say. A 1us input pulse might actually not be giving your opamp enough time to properly slew. Also, what is the value in volts of the input step?
Finally, what is the rise time/ fall time of the pulse?
Ramakrishna RSSM
Reply #3 - Oct 28th, 2015, 11:41pm
Thanks for your reply saqibshah.......
Input 1 mS pulse with V1=1.5 V and V2=1 V ----> slewRate = 45K V/S
Input 1 uS pulse with V1=1.5 V and V2=1 V ----> slewRate = 45M V/S
The Diff-Amp is designed in gpdk180 with VDD=1.8 V.
Follow the attachments for the waveforms.....
I haven't specified any rise/fall time So rise/fall time would be 1% of period i.e: for
1 mSec pulse rise/fall time is 10 uSec
1 uSec pulse rise/fall time is 10 nSec
Could you please explain how to identify PROPER SLEWING......?
A Kumar R
India
Reply #4 - Nov 6th, 2015, 5:48am
show your amp structure, how much are you expecting based on calculations, where is input where is output.
