Jul 17th, 2024, 4:37pm
Measure capacitance of a node in ring oscillator (Read 1619 times)
baab
EA
Dec 10th, 2015, 11:53pm
I would like to measure the capacitance between a node to ground in my ring oscillator.
I am running transient analysis. As you see the oscillator have no input and output.
Is there a way to do that in Cadence?
raja.cedt
Re: Measure capacitance of a node in ring oscillator
Reply #1 - Dec 14th, 2015, 11:42pm
Add a dc current source with 0mA dc and 1A ac value. Run transient and note down the time period. Do a ac times sim over the time period. Now you can find ac voltage on that node over the period. You have voltage and current hence find the cap.
Ps: cap corresponding to a node in ring oscillator varies over the period, for the oscillation frequency calculation, I would suggest use mid rail cap.
Raj.
