Aug 15th, 2024, 6:05am
pss confusion (Read 1891 times)
exp
pss confusion
Jan 25th, 2016, 8:25pm
I have a downconversion receiver consisting of an LNTA, passive current mode mixer driven by fLO=2.2GHz and ideal current sink (a port). Bandwidth is 700MHz (i.e. 1.85G - 2.55G). At baseband (I/Q) this would be -350 MHz ... 350 MHz (or 0...700 MHz). However, currently I am only using the I branch. Hence it should just be symmetric.
For pss, I set hb engine with 2.2G beat frequency and number of harmonics: 13
Now I would like to measure the gain of the LNTA. For this reason I need to measure the current at the sink port at baseband and divide it by the voltage of the LNTA input at RF (and multiply by pi/2 to account for the conversion loss of the passive mixer). Hence I set up a relative sweep from -350 MHz to 350 MHz and relative harmonic -1.
My question: Is this correct?
In the next step, I want to check the S11 of the system at RF. Hence I set up psp with sweeptype absolute from 1.85G to 2.55G (harmonic 0). Is this correct?
And finally, the noise figure with pnoise: I use again a relative sweep with relative harmonic -1 and sweep from 1k to 700MHz. The reference side band is set to -1.
Is this correct?
asu2011
Re: pss confusion
Reply #1 - Nov 2nd, 2016, 12:09am
hello exp
i wanna to know your setup is correct?
