Sep 4th, 2024, 10:20am
Ocean script for corner simulation (Read 2145 times)
robotist
Feb 26th, 2016, 4:32pm
Hi, my name is Kim.
I want to simulate with variable corner and parameter.
So, I use ocean script below.
foreach(corner list("ttt" "fff" "sss")
  modelFile(
        list("/user/mylib/mycorner.scs" corner)
  paramAnalysis...
 paramRun()
ocnPrint...
mycorner.scs is below
section ttt
endsection ttt
section fff
endsection fff
section sss
endsection sss
Simulation is successfully completed. But the reault shows that
there is no corner sweep, just only one corner.
Could you explain why only one corner is simulated?
Thanks for read.
ValarMorghulis
Re: Ocean script for corner simulation
Reply #1 - Mar 23rd, 2016, 12:12pm
Hi Kim, I am just curious why you are using Ocean script to run corner analysis. As far as I know it is really easy to get corner results using the ADE XL in GUI mode. Is there any advance of using Ocean scripts over ADE XL?
Thank you.
View Profile ValarMorghulis sazjad   IP Logged
