Jul 16th, 2024, 5:24pm
Pin annotation (Read 1797 times)
robotist
Pin annotation
Mar 10th, 2016, 4:01am
Hello. My name is Kim.
If I have instance named I0 and I want to save current #1 pin(pin name is GND).
So I use ADE-Outputs-To Be Saved-Select On Schematic.
But there is only save I0:1 not I0:GND in netlist.
Surely using cdsTerm(), I can spectre simulation. But I want simulation other tool with only spectre netlist.
Is there any way to save pin name(I0:GND) instead of pin number(I0:1) in netlist?
ULPAnalog
Re: Pin annotation
Reply #1 - Mar 10th, 2016, 10:29am
Hello
I am unable to follow what exactly you wanted from your post. Could you post a schematic to get a better idea.
Thanks and regards
