Jul 19th, 2024, 12:34am
Reading verilog a module's branch current (Read 6612 times)
AA
Mar 31st, 2016, 3:26pm
I'm trying to probe the current flowing from output port "out" to output port "out1" in the following "cccs" module:
module cccs(ctrl, in, in1, out, out1);
       input in, in1, ctrl;
       output out, out1;
       electrical in, in1, out, out1, ctrl;
       parameter real Ron = 1k;
analog
begin
       if (V(ctrl) == 0)
               V(out, out1) <+ 0;
       else
               I(out, out1) <+ I(in, in1)* I(in, in1) * Ron;
This module is instantiated as part of hspice netlist as follows:
xI1 net5 n21 n31 0 net777 cccs
I would like to examine the current of the current source between nodes 0 and net777. As an attempt to solve the problem myself, I added a probe statement to my hspice netlist as follows:
.PROBE tran I5(xI1)
However, hspice reports the following warning:
**warning** only v and i function supported
  for va device: xi1
Is there another way around this please?
Please note: this module is taken from this VA file   http://nimo.asu.edu/memory/download/pcm/model.va
and modified a little.
Re: Reading verilog a module's branch current
Reply #1 - Apr 4th, 2016, 8:35am
try
.PROBE tran i(xI1.out1)
Reply #2 - Apr 4th, 2016, 3:23pm
if (V(ctrl) == 0)
That is never a good idea.
AA
Reply #3 - Apr 9th, 2016, 8:39pm
Geoffrey_Coram wrote on Apr 4th, 2016, 8:35am:
try
Thanks Geoffrey_Coram! This seems to work.
But another problem appears now:
Note that the quantity I(xI1.out1)=I^2*R must always be positive (or always negative, depending on measurement direction).
However, the quantity fluctuates between positive and negative values. Is this possible? Or am I doing something wrong?
AA
Reply #4 - Apr 9th, 2016, 8:41pm
Ken Kundert wrote on Apr 4th, 2016, 3:23pm:
if (V(ctrl) == 0)
Thank you for the comment Ken. I appreciate if you can explain why this is not a good idea.
Reply #5 - Apr 11th, 2016, 12:43am
It is almost never a good idea to do an equality test on real number. It is very unlikely to trigger. Worse, it it ever does trigger, the model switches its nature from being a current source to being a voltage source. I don't know what you are trying to model, but it is nothing that could exist in nature. Doing such things will just lead to simulation problems.
Is there any reason why you have to output your computed quantity? You might be better served to simply save it in a local variable inside the module and then just plot that.
Reply #6 - Apr 11th, 2016, 9:27am
AA wrote on Apr 9th, 2016, 8:39pm:
Is the value outside the tolerances?  Eg, if abstol is the default 1pA, then any value less than 1pA is understood to be indistinguishable from zero.
AA
Reply #7 - Apr 13th, 2016, 11:42am
Ken Kundert wrote on Apr 11th, 2016, 12:43am:
Thanks, this is really very educating Ken. I did not write this module myself.  This module is part of the phase change memory cell model by ASU (the verilog-a model is here: http://nimo.asu.edu/memory/download/pcm/model.va , the hspice testbench is here: http://nimo.asu.edu/memory/download/pcm/1t1r.sp , and the model manual is here: http://nimo.asu.edu/memory/download/pcm/manual.pdf ). The cccs module is meant for power consumption calculation.
The reason: I would like to measure the power consumption of the circuit during a period, and integrate that over time to calc the energy. Makes sense?
I simply want to print (or probe) the verilog-a quantity I(out,out1) in hspice netlist.
Both I(xI1.out) and I(xI1.out1) outputs something different. I know because I added a $display statement to output the verilog-a quantity I(out,out1), which is all positive as expected. Both I(xI1.out) and I(xI1.out1) are fluctuating between positive and negative.
So, the question is: is there a way to ".print" I(out,out1) from within the hspice netlist?
Is there a way to do this from within the verilog-a module?
By the way, I'm new to both hspice and verilog-a.
Reply #8 - Apr 14th, 2016, 1:50pm
You should be able to plot the value of your local variables, but unfortunately I have never used HSPICE, so I can give you no guidance as to how to do it.
Reply #9 - Apr 21st, 2016, 12:44pm
For compact modeling, most of the local (internal) variables are not interesting, so we set up a special convention for declaring operating-point variables by using an attribute:
(* desc="transconductance" *) real gm;
Then "gm" should be available as op-pt info in the same way that you get op-pt info from a BSIM4 transistor.
