Jul 18th, 2024, 2:22pm
Parametric sweep of Vth and OUTPUT to see the effect of Vth variation on OUTPUT (Read 3523 times)
ValarMorghulis
Apr 14th, 2016, 10:34am
I am using Cadence 6.1.6 and Spectre simulator.
I am trying to sweep the threshold voltage of the transistors to see the effect of variation on the output signals. Can anyone please help me how can I do that in ADE?
Thank you for your time and help.
VM
View Profile ValarMorghulis sazjad   IP Logged
AA
Re: Parametric sweep of Vth and OUTPUT to see the effect of Vth variation on OUTPUT
Reply #1 - Apr 14th, 2016, 12:08pm
ValarMorghulis
Reply #2 - Apr 14th, 2016, 2:03pm
Thank you for your reply.
This tutorial tells us about how to sweep the gate voltage. I am trying to sweep the threshold voltage which is a model parameter. Do you know anything about that?
Thanks!
AA
Reply #3 - Apr 15th, 2016, 12:45pm
If you can change the threshold parameter manually, you can also sweep it.
Try this:
In the value field of this parameter, instead of a numeric value, enter a variable name, e.g., v_th.
In the ADE, click Variable -> Copy from Cell view
You will see your v_th variable.
Click on Tools -> Parametric analysis, and with your variable selected, enter the range.
AA
ValarMorghulis
Reply #4 - Apr 15th, 2016, 1:05pm
Just to make sure, are you saying to modify the model file? In the model file Vth value of the transistor is depended on several parameters.
Or just to the define the value of applied voltage to the gate as a variable(Vgs)?
Thank you.
AA
Reply #5 - Apr 18th, 2016, 12:02pm
Sorry, my semiconductors background is rusted.
Yes, you are right, the threshold voltage is a dependent variable, therefore, you cannot sweep it. However, you can sweep the other parameters that directly influence its value iff the model exposes these process-dependent parameters to you (which I doubt).
Anyway, I found this relevant thread:
https://groups.google.com/forum/#!topic/comp.cad.cadence/jB7iz9lwiLw
