AA
If you can change the threshold parameter manually, you can also sweep it.
Try this:
In the value field of this parameter, instead of a numeric value, enter a variable name, e.g., v_th.
In the ADE, click Variable -> Copy from Cell view
You will see your v_th variable.
Click on Tools -> Parametric analysis, and with your variable selected, enter the range.
AA
