Jul 18th, 2024, 10:24am
plot current of output node in frequency domain in Cadence (Read 2200 times)
rames
Apr 14th, 2016, 1:05pm
I want to plot current of output node in frequency domain with ac analysis in Cadence using this equation in ADE :
dB20(abs(IF("/I0/Vo")))
which Vo is output node voltage, and I0 is current related to output voltage.
but always i get error that it can not calculate IF(nil).
Would you please telling me what is the problem with it?
Thanks alot
ULPAnalog
Re: plot current of output node in frequency domain in Cadence
Reply #1 - Apr 14th, 2016, 1:29pm
You are, most likely, not saving the current through the node of interest. Otherwise it will report the signal of interest as unkept.
rames
Reply #2 - Apr 14th, 2016, 11:12pm
Thank you, it worked.
