rames
Hello, I want to plot current of output node in frequency domain with ac analysis in Cadence using this equation in ADE : dB20(abs(IF("/I0/Vo"))) which Vo is output node voltage, and I0 is current related to output voltage. but always i get error that it can not calculate IF(nil). Would you please telling me what is the problem with it? Thanks alot
