Jul 21st, 2024, 4:15pm
current measurement through $cds_iprobe (Read 1349 times)
AMS_ei
May 26th, 2016, 2:09am
Hi, I am trying to measure current flowing through R2 with the help of verilog-AMS.
1. The following is my SPICE netlist file (input.scs):
simulator lang=spectre
global 0
subckt TEST in out
R2 (in out) resistor r=1K
R1 (out 0) resistor r=1K
R0 (in 0) resistor r=1K
ends TEST
2. The following is my top.v file:
module tb_top();
wire in;
wire out;
TEST test (
    .in(in),
    .out(out)
dc_gen Idc_gen(
             .out(in)
curr_bfm Icurr_bfm (
                  .check_curr1()
3. Following is the dc input voltage generator file which is basically the input voltage to the circuit
`include "disciplines.vams"
`include "constants.vams"
//`timescale 1ns/1ps
module dc_gen(out);
output out;
electrical out;
analog begin
V(out) <+ 5 ;
4. Following is my amscf.scs file;
include "$TB_ROOT/test/input.scs"
include "$TB_ROOT/test/acf.scs"
amsd {
    portmap subckt=TEST
    config cell=TEST use=spice
5. Following the file with which I am trying to measure current through R2.
module curr_bfm(check_curr1);
output check_curr1;
electrical check_curr1;
real real_cur;
analog begin
real_cur = $cds_iprobe("tb_top.test.out");
I(check_curr1) <+ real_cur;
6. Following is the probe.tcl file by which I am probing the signals.
probe -create -shm -all -analog -flow
run
The above setting I am running with irun. But, there is no value of current showing through R2.
Could you please tell me if there is anything missing to get the value of current?
Thank you.
Re: current measurement through $cds_iprobe
Reply #1 - May 28th, 2016, 11:15am
Well, in your testbench you did not actually pass anything into your current checker:
			.check_curr1()   <---- this cannot be right
Second, you should never use $cds_iprobe unless you know what you are doing. It is inaccurate and when used in a circuit like this causes instabilities. Specifically, if you use $cds_iprobe you must first understand that it is inaccurate and how it is inaccurate so you know whether you can tolerate that inaccuracy. Second, you should never use the output of $cds_iprobe to drive the circuit itself.
output check_curr1;
real real_cur;
analog begin
Instead, you should just use the normal mechanism for measuring current in Verilog-A.
real real_cur;
analog begin
    real_cur = I(check_curr1);
Finally, this collection of models seems overly complicated and hopelessly confused. Perhaps if you described what you wanted to do we could just tell you how to do it. Regardless, you should read Introduction to Verilog-A.
AMS_ei
Reply #2 - Mar 19th, 2017, 10:03am
Hi Ken,
Thank you for your valuable inputs.
Actually, I would like to measure current of a SPICE net ( here in this context it is through out) with the help of Verilog-A/MS code.
Thank you.
Kind regards.
Reply #3 - Mar 20th, 2017, 1:04pm
What do you want to do with the current measurement? Do you want to print a message giving its value, or do you want to output a voltage (like a CCVS)?
Also, one can measure the current through a branch. If your "SPICE net" has more than two terminals, it doesn't really make sense to talk about measuring the current of the net.
AMS_ei
Reply #4 - Apr 18th, 2017, 8:44am
Thank you Ken and Geoffrey Coram.
I got it now.
