Sep 16th, 2026, 4:38pm
The difference between test bench and test on DE1 board (Read 1769 times)
quan
Jun 19th, 2016, 1:38am
I am a student and I am working on a homework. Shortly, I will summary
shortly the hw's requirement. It said some thing like that: At first,
when counter goes from 0->7 then led 1 on; when the counter up to 8 then
led 2 on, up to 9 then led 3 on. Next, when the counter comes to 10, it
depends on a switch, if switch is on, led 4 on, if switch is off led 5
on. And if led 4 on, it still to be on until counter comes to 14 then
counter reset to 0 and comes back to first stage which means led 1 on.
And similarly, if led 5 on, it still to be on until counter comes to 22
then counter reset to 0 and comes back to first stage which means led 1.
The requirement is described by a lots of word but shortly it will be
like that after I design FSM for the problem. When I finish my code,
test bench runs OK but when I run on Altera DE1 board, it did not run
like my expectation. When the counter comes to 8,9,10 it runs nicely but
next when led 4 or led 5 on, it immediately comes back to stage 1 (led 1
on). Led 4 should be on 4 seconds or led 5 should be on 12 seconds
before come back to stage 1. In test bench, it waiting but in the board
nothing is waiting.
This is my code, hope you guys help me.
module controller(sw, clk, rst, led, y, Y); //This is top level module
input sw, clk, rst;
output [4:0] led;
output reg [2:0]y=0,Y=0; //y: present state; Y: next state
parameter [2:0] fer=0, ready=1, prepare=2, transfer=3, flush=4; //define finite state machine
reg [4:0] count=0; //counter
frequency_divider C1(clk, clk_out); //divider frequency for DE1 board, I use pin L1 (50Mhz)
always@(count, sw,y)
           case(y)
                       fer: if (count==8)
                                                           Y=ready;
                       ready: if (count==9)
                                                           Y=prepare;
                       prepare:  if ((count==10) & (sw==0))
                                                           Y=flush;
                                         else if ((count==10) & (sw==1))
                                                           Y=transfer;
                       transfer: if (count==14)
                                                           Y=fer;
                       flush: if ( count==22)
                                                           Y=fer;
                       default: Y=2'bxx;
           endcase
endcase
always @(negedge rst, posedge clk_out)
   if (!rst)
   y<=fer;
     else
       y<=Y;
 if (!rst)
   count = 0;
     else begin
       count = count + 1;
       if (y==transfer && count==15) //This to reset the counter
         count=0;
       else if (y==flush && count==23)
           count=0;
assign led[0]=(y==fer); // led 0 on when the system in fermertation stage (stage 1)
assign led[1]=(y==ready);
assign led[2]=(y==prepare);
assign led[3]=(y==transfer);
assign led[4]=(y==flush);
module frequency_divider(clk_in, clk_out);
 input clk_in;
 output clk_out;
 reg [31:0] num=0;
 wire clk_out=num[24];
 always @(posedge clk_in) begin
   num <= num+ 1;
module test_controller; //test bench
wire [4:0]led;
reg sw, clk, rst;
controller C1(sw, clk, rst, led);
initial begin
sw=0;
clk=0;
rst=0;
#2rst=1;
always begin
#1 clk=~clk;
always begin
#100 sw=~sw;
