Jul 17th, 2024, 1:33am
Gaussian noise real generator for pure digital oriented simulator (Read 2600 times)
Narasimhan
Aug 24th, 2016, 6:07am
Is there an inbuilt verilogams/systemverilog function that generates real normal distribution. I am running ams simulation will all analog blocks modelled using ams wreal/systemverilog real so that spectre is not called and only the digital simulator is used.
I basically need something similar to $random but one that is gaussian rather than uniform and which outputs real value and not integers.
If no system function is present then is there a simple way to get one.
The $rdist_normal present in verilogams works only in analog scope.
Thanks in advance.
Re: Gaussian noise real generator for pure digital oriented simulator
Reply #1 - Aug 24th, 2016, 7:43am
What about $dist_normal?
Narasimhan
Reply #2 - Aug 25th, 2016, 5:55am
$dist_normal returns an integer value. I guess I can convert it to real and use it. It would be better than writing code to generate normal distribution from scratch.
